help with my 2g talon tsi awd turbo
turbox
Feb 19, 2007
rlsinore, California
just tonite i was driving normal just cruising it and out of nowhere my car seemed to try and stop like if i floored the brakes and then got back to normal but then i started hearing a loud clanking noise coming from my engine and it got louder as i steped on it more....i got it all the way back home .......it seems like sumthing is just broken and flying around in my engine.....i found a video on you tube and my car does this exact same noise ...eat could it be??????? help please i love my dsm:(:cry: ......<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/iQpsO8m4O44"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/iQpsO8m4O44" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
its drving pretty good i guess for ### it is its just that when i floor it the rpms hit 3000 and studder then after a while itll go back to normal.....it picks up speed well though aslong as i dont go over 3000 rpms....its just that the noise is so loud and annoying...
Look for anything loose around the engine that could be causing it. You'd hate to find out it was something simple after you pulled your motor.
Check compression, then go ahead and remove the valve cover. See if you see anything weird with rockers, springs, or as much of the valve as you can see. If you still see nothing, drain the oil and look for anything that's not oil (i.e. shavings, RTV, etc.). After that, you can try taking the oil pan off and looking at the rods and pistons.
That should give you a pretty good diagnostic idea of what the problem is. If you have any trouble seeing problems or you aren't sure what a messed up part looks like, just post some pictures of above circumstances.
Good luck!
bad head gasket and bent valves???....what happened or ### caused this?.....i need help i dont want to fix it so it could happen again because i didnt fix all of it
this happiend to the kid because he was running 19psi on an all stock motor that wasnt the turbo one to begin with ROFL . you can also bend valves if your downshifting at to high of rpm's that can #### it up bigtime.
