help with choosing injector size, hearing 2 different sides
brrrnntsshhhh
75
Aug 28, 2004
Tucson, Arizona
Hello, I am having trouble choosing the injector size I need. I am going to be running a pte 50 trim, dsmlink, walbro 255, aeromotive fpr, and I plan on runing a max of 24-26 lbs of boost. My friend has a similar setup but uses Emanage for his tuning, and he told me to get 680cc because anything higher would be hard to tune. However, other people have told me to get larger injectors since I am going to be running dsmlink and it won't be that difficult. I figured I would come here to get some quick answers before I ordered my injectors.
One other thing to note is that I am fwd and I don't plan on upgrading to a larger turbo in the long run. This setup will more than likely be my final setup.
Thanks,
Troy
You have DSMLink, get the biggest injectors you can afford (ie 980's). That way, if you ever upgrade turbos again, no need to buy more injectors. DSMLink has proven to be able to run up to like 1600cc injectors. The emanage, like other piggybacks, is limited to scaling injectors only 50% bigger than stock.
I completely agree, tuning injectors is cake with DSMLink. Go with something big, in case you want to upgrade more in the future. Believe me, I have said "this is my last upgrade" about 9 million times already and it never ends.
