HELP! - Starter will not crank, no voltage at solenoid
mnetwork
1,017
Feb 25, 2006
New Milford, New Jersey
Ok, trying to prime my motor the car is almost done. The starter will not click or move or anything. Battery is ok and wires and grounds are ok because I can jump the solenoid with a screwdriver. I am checking voltage at the little black connector that goes to the solenoid while turning the key and I am getting nothing. What can this be? :confused:
SOLVED
This was it...
http://www.dsmtuners.com/forums/newbie-forum/358182-starter-wire-solenoid.html
  • Wanted 6 bolt NT water pipe
    • chrisman287
