Help on Cluster Gauge
JohnRicey
82
Jan 19, 2010
Orange County, California
Okay guys i just bought a white cluster gauge but problem is i do not know how to install it i already removed everything and place the new gauge on top of the old one, but problem is i do not know how to wire it in the instruction was badly instructed but it did mention something about 12v can any one help me or give me a link on how to install an aftermarket cluster gauge.
Thanks :thumb:
just thinking right off the head, wouldnt that 12v need to be connected to your gauge cluster light knob?
thats the knob that controls the light and also turns it on and off, i mean hopefully you dont need instructions on how to install a wire and ground.
but if you do ill be in more detail.
usually those gauge faces don't have a dimming function on them. you could wire it to the the lighting circuit but you would probably have to turn your dimmer switch all the way up to make it work. for something like that i would get a fuse tap TESSCO Image Zoom, click window to close. and hook it up directly to the fuse box. just try to make sure you put the fuse adapter on the side of the fuse so that if something happens you will still blow a fuse and not catch something on fire.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
