1G Help needed with CEL Codes
thakingcb7
196
6
Feb 8, 2015
Lewistown, Pennsylvania
Just picked my car up from the garage... was getting the head gasket fixed. Me and the mechanic test drove it and it ran fine. I drove it home nearly 20 miles and still... it ran fine. Couple hours later I jump in to take the car to work and in maybe 1/2 a mile the CEL kicks on and car starts running real rough like stumbling and decreased power. I jump off the first exit I can and pull the codes... 12, 13, 25, and 44. At this point I'm just too exhausted to even think straight so if anyone could give me a few pointers on where to begin figuring this out I'd greatly appreciate it. All plugs are on their respective sensors and tight as well as vacuum lines and such.
11. Oxygen Sensor
12. Air Flow Sensor
13. Intake Air Temperature Sensor
14. Throttle Position Sensor
15. Motor Position Sensor
21. Engine Coolant Temperature Sensor
22. Crank Angle Sensor
23. No 1 Top dead center sensor
24. Vehicle Speed Sensor (Reed Switch)
25. Barometric Pressure Sensor
31. Detonation Sensor
36. Ignition Timing Adjustment Signal
41. Fuel Injector
42. Fuel Pump
43. EGR (California) ((This is also a common code when the ecu capacitors have to be replaced.))
44. Ignition Coil ((This is also a common code when the ecu capacitors have to be replaced.))
With that being said was the running fine before the shop these all sound like codes that would be related to parts being removed in the head removal process, Im not quite sure, I would do a boost leak test, make sure you're timing is correct, check the plugs and wires to see if they're hooked up right, and call the mechanic and tell him he should fix it hopefully someone else will chime in
I know what the codes are but we (me and the mechanic) got the car home. Turns out the wires on the power transistor are loose. I'm still confused as to why that would have any affect on the intake system causing 3 of the 4 codes.
