help n/t afc settings
ddmn146
Jan 18, 2004
albuquerque, New Mexico
i have a 92 eclipse gs with the 4g67 1.8l dohc engine in it and my mods so far are as follows short ram intake setup with k&n filter heddman chikara 4-2-1 header 2.25 full catback from the header back 1.5 lb undrdrive crank pulley safc 2 autometer air\fuel ratio gauge and a set of cams out of an awd gsx which are more aggressive but since i put the cams in i am running leanand stock fuel settings just dont cut it anymore i was wondering if anyone would have any recommended hi and lo safc settings for my setup please i need help
congradulations for having the first 1.8 dohc ever. The 1.8 is a sohc, and if you have a dohc motor that means you have a 4g63.
You might want to check out 4g61t.org as they deal more with the 4G67 DOHC there.
defrag010, yes sir there exists a Mitsu 1.8l DOHC. They just didn't come stock with a DSM.
