Help Me Will This Fit?
forcd4
Jun 27, 2003
Ankeny,
My question is I just purchased a set of ADR Spade rims. They are 18's with Nankang NS2 tires. The tire size is 225/40/18x7.5. The offset is 42mm I think. I want to put my Progress springs on that drop it 1.5in. Do i need to roll the rear fenders on the rear to clear or not. Have heard some people do not and some do. Confused. I plan on installing a shim kit for the rear camber. Also, does the front come out ok? If you have any good pics of fender rolling on your car can you post them. Also, if you something similar to this setup can you post pics. Thnaks for your time.
P.S. My car is 1997 eclispe gs
forced4 -
I'm down an inch and a half right now and have 18" nankang NS-2 225/40/18 tires on my ADR rims. Check my profile for pics. You'll be happy with that drop, you'll scrape here and there if you're not careful, but def a good street set up, looks great. No need to roll the fenders in the back, however if you wanted to do a drop in the back over 2" you would need to. For more info on a do it yourself camber kit. Check out this link... http://bellsouthpwp.net/a/x/axis06/. Hope this info will help.
  • Wanted 6 bolt NT water pipe
    • chrisman287
