EcliptikIlluzio
- 87
- 1
- Feb 3, 2003
Myrtle Beach,
South Carolina
I recently rebuilt my engine. It is a 1990. I have most all the plugs from the wire harness plugged into there respectable locations. I have one plug that doesn't seem to go anywhere. It is behind the intake manifold next to the firewall and near the fuel solenoid where you tap the boost gauge into. I have the solenoids, knock sensor, coil, PTM, thingy on AC all plugged in. Stretching the wire it seems to want to reach on the intake manifold somewhere. It is a big 4 prong plug I think or maybe it is the big 2 plug one.
Also there is some type of relay/resistor that is mounted on the back of the big mount that supports the intake manifold. It is a 2 toothed plug with one tooth running horizontally and the other running vertically (like the on on the thermostat housing). Where/What in the world plugs into that?
I hope to find out this stuff by tomorrow so I can finally get the car back on the road. Let me know if you have any ideas where these plugs go?
Thanks.
Thanks.
