Help! Is this a stuck injector or a bad coil pack?
casper_talon
86
Nov 29, 2006
Quebradillas, Puerto Rico, Central America
Hey people, hope you can help me. Well, my car started fine on the morning, ran great to school, then when I was looking to park it, I was idling for about 1-2 minutes, and the car got real rich(had to rev a few times and let the clutch slowly at about 2000rpm to get the car moving). It did this every time I stoped. Then, I shut it down. About 4 hours later, I went to start it, and it did like it was going to start, but died. Then it just cranked, and a heavy fuel odor came. I took out the spark plugs, they were black and smelled like fuel. I bought 4 new ones, changed the coils, and the spark plug wires, tried to start again but the car just said no. I left it there, the next day I went to start it again, and the car started fine. When I got home, shut down the car, and tried to start it again, the same thing happened, gas smell, just cranked. Can this be made by a stuck-open injector, or is it coil-spark problem? Could it be the ECU? The car is a non-turbo, but it has a turbo fuel pump + re-wire & relay, and the pressure is at 45-50psi when the car is running. Thanks for any help you can bring me!
I will check that out. It's just that I changed the coils, new spark plugs and wires, and the problem remains. I will check the ecu to see if it's that.
