Help installing a aftermarket radio
4g63turbo84
614
Dec 10, 2008
ocala, Florida
I have put a center console out of a dodge avenger into my 2 g, But I have ran into trouble trying to put a radio in. In the dodge avenger the radio sits at 90 degrees But in the eclipse is the radius it at an angle I want to know what am I missing to put the radio in..
Radio cage needs to be swapped too. Its the metal part around the radio. You are also moving from a double DIN enclosure (touhscreen nav, dvd, etc) to a 1.5 din enclosure. So you will need to buy a radio install kit for an avenger.
You might try to get the radio brackets for an avenger. If that doesn't work then you could just drill some new holeS in the brackets you have so the radio sits at the angle you desire.
