Help im confused
kraniun
54
Jan 30, 2003
well my timing belt went out and yea nasty results. All pistons are nicked and all exhaust valves gone. Im thinking of getting new pistons but is a 7 bolt. CW i know overrated. But since i have the oppurtunity i was thinking about a 6 bolt swap. Lately ive been reading here and their about 7 bolt stroker swaps and im seriously considering one. The main question I have is can I still use the block I have in my car. Do I just replace the crank with the stroker rods and pistons using the block i currently have? will it bolt right in ? I have searched but havent seen anything that answers my question. Links to articles/faq's that will help would be great. Thanks for your time hope you can help.
i found several things out and they dont answer straight fwd what i need to know. They talk about using the 4g64 block. I was wondering if i can use my block in the car the 4g63. Any one has any answers?
the design of the 2g 7bolt motor is pretty much the cause of crankwalk, changing the crank will do no good in preventing it, just get a 6bolt, and if you want to go stroker, do a 6bolt 4g64
