Jiggalude
- 284
- 0
- May 14, 2005
Lancaster,
Pennsylvania
My car runs great. But it will only boost 9 psi. When I floor it, the AFR is between 11 and 12 so they are good. But even with my MBC closed all the way, I'm still only maxing 9 psi. When I'm half throttle just cruising, I can hear my stock BOV whistling, it's leaking air, I don't know if that is normal or not, and I can't tell under boost if it's leaking or not. Also, while cruising the AFR's bounce back and forth constantly between 13 and 15, but hold pretty steady around 14.5-15 at idle. And when the car is decelerating, the AFR gauge maxes out and goes to 3 dashes - - -. I'm just confused because from what I know about turbo's if I have big boost leak, shouldn't I be running very lean at WOT? Someone please help!
