Help finding bushings
sapper12b
71
Mar 7, 2013
St. Robert, Missouri
I need these two bushings. This is on a 90' dsm. One is the bracket where my finger is pointing to and the other is inside the car on the bottom of the shifter assembly. My shifter can be in 1st gear but seem like its in 4th, if that makes sense.
Give me a few minutes and i will get you the part numbers. I have to locate mitsubishi asa in my computer.
Take a picture of it when you go to a dealership they can get the part number for you those should be able to be purchased jnz tuning can help too, pauls good, I can help too I used to work for a mitsu dealership here in town.
Shift selector lever bushings are MD719165, you will need 2 of them.
1990 Shifter base bushings are: MB580217, you will need 4 of them.
The selector lever,thanks a lot. The other one is not the the base ones, it may not be a bushing it's circled in red.
Well, you asked for bushings, I gave you the part numbers associated with the two spots you had shown in the pictures.
The assembled bolt is MS240147 x 4
The bushing is MB580217 x 4
The spacer below the bushing is MB659625 x 4
Ok, I will order them, they r cheap.
The bushing for the inside of the car is MB307949 circled in red. If anyone could help me out with the one on the tranny, with a pic if possible that would be great.
Be careful, 1990 is totally different for the interior bushings, the part numbers I posted are specifically for 1990 shift lever assemblies
Ok, Ya I emailed jnz tuning they have it for a 1g just making sure it will work.
And I don't need the shift lever assembly on the inside I need the shifter cup bushing, and then the lever bushing on the tranny
  • Wanted 6 bolt NT water pipe
    • chrisman287
