help!!! evo9 mr stock gauges in 1g
tfaulk21
153
Aug 28, 2011
Mt. Holly, North Carolina
I'm trying to hook up my EVO 9 Mr stock gauges that consist of volts tempature and boost or turbo. The only problem is the guy cut up the harness pretty bad so he chunked it. I need the connectors that go in the back of the gauges two are 5 prong and the other is 2 prong is there anything I can do to get around buying the harness and getting them to work?
Soldering each pin to new wires? And I think the gauges go boost/volt/oil temp and the oil temp uses a sensor on the drain plug.
-shane
