help ! doing 6 bolt swap need clarifcation
Okay I can use the 2g TB with the 1g Intake or should I swap the Intake also.?
which will solve the MAP relocation into the brake booster.
Not going to be getting 1g TB now if I dont have the right one. Need to get the car running first. And I can change that with the engine in the bay.
So what should i do.
if i go with 1g intake and 2g TB which Gaskets do i get?
Yeah the 2g TB is NOT ideal on a 1g Intake manifold, the 2g Throttle body is 52mm vs. the 1g 60mm throttle body. Im merely suggesting you can use your 2g tb for now until you find yourself a nice 91-94 Throttle body. I prefer the NON turbo 91-94 Throttle bodies myself. Check Ebay or Craigslist.
is 91-94 TB with an ISC needed? or just TPS , cause i found one but doesnt have ISC
do i need this for 6 bolt into 2g swap ?
