HELP!!! Destroyed 4g63's with no explanation
sprocket2005
35
Oct 29, 2007
Burgettstown, Pennsylvania
I have had 2 4g63's with fresh rebuilds and both of them came apart with less than 2000miles on them. The first one that i got was from a 1990 talon, i bought the car from a guy in detroit and he had just rebuilt the motor, he put a new oem crank in it, new oem rods, pistons, the whole nine yards. All Mitsubishi parts. I towed the car back home, (because i went to detroit alone and couldnt drive two cars back), drove it less than 100 miles, then discovered that the oil pan he had on the motor was kinda dented, so i bought another oil pan, pick up tube and gaskets, to fix it. When i pulled the oil pan i saw metal peelings and shavings in the bottom of the oil pan. The crank was ruined, and the bearings were too. There were metal shavings everywhere and i knew it was serious. About a week later i bought another 4g63 from a guy that worked at Slowboy Racing ( it was the motor out of his talon and it had less than 2000 miles on it) to drop in my talon and it was supposed to be a bad ass motor. I get the motor put less than 100 miles on it and it does the same thing as the other motor did.:cry: Metal shavings everywhere, crank destroyed, scratched a cylinder, and the thrust bearing looked the worst just like on the other motor. So i went to Slowboy, talked to the guy that sold it to me, showed him pics of it all, and another tech guy in the shop suggested that it could be a result of running Mobil One Synthetic oil. Not so much the fact that its mobil one he said, but because it was synthetic oil. Could this be true?? I cannot figure out what is going on and nobody at Slowboy could either, Does anyone have any ideas as to what could be causing this
I'd like to add that i only ever hit the rev limiter ONCE, between shifts, and it was on the 2nd motor. I DID NOT beat the hell out of either of them. I was talking to a guy and he said that it may have been because the guy who assembled the 2nd motor was so picky that he wouldnt accept a crank unless when he measured the journals they were slightly oversize so that he could polish them himself, his theory was that maybe he didnt polish one down enough and there wasnt enough clearance. Another guy, who looked at the motor thinks it may have been a dirty assemble that caused the 2nd motors problems, I have no clue what happened, but both motors' problems started at the thrust bearing i'd say, atleast it looks that way and its messed up the worst on both motors. I DID NOT shift from 3rd to second or anything and overrev the motor, and i did not beat the shit out of the second motor, or the first one. Like i said I dont know what happened, but if anything unexplainable was gonna happen to anyone in the world, it'd be me. By the way, when i pulled the plugs on the 2nd motor they were white, but running lean couldnt cause the thrust bearing to shred apart.
I'd say the thrust bearing went first, because it was torn up the most. It looked exactly the same as the thrust bearing from my other motor.
Bad Luck had to be it. I know it was assembled correctly.
Everyone who keeps saying that this happened because of the oil leak, YOU ARE DEAD WRONG. I knew about the oil leak, asmo told me everything about the car before buying it and left nothing out and i drove it home from his place to mine. It was a 45 mile trip home and i stopped 4 times to check/add oil. The oil level NEVER, NOT EVEN ONCE dropped near or below the bottom safe line on the dipstick. Once i got the car home it just sat for a couple weeks, i drove it 3 times during those 2 weeks and i checked/added oil EVERY TIME before starting or driving it. I took the car on very short trips less than 10 miles each of the 3 times and when i got back home i shut it down, let it sit for 10 mins, then checked the oil level to make sure it was in the safe range still, and it was everytime. That way i knew i couldnt have done any damage by running it low on oil, because i never ran it low on oil. And I'm not pointing fingers at anybody, this is nobodys fault, just falls under shit happens. It is ridiculous that certain people are assuming that I did something to cause this, because i did absolutely nothing wrong, and asmo didnt either. I checked all the fluids before during and after EVERY SINGLE TIME i drove it. I have the worst luck ever, ask asmo, one night i went for a ride in his evo with him, and his evo started acting up. I cant remember what it was doing exactly but as soon as i got out of the car it quit, and as far as i know it hasnt done it again since. Point being, shit happens, i realize that this was not anyones fault, and i was an asshole to asmo when this happened, sorry man. All i wanted to accomplish by posting this thread was to get an idea of what could of happened, so that when i rebuild the motor i can watch out for some peticular things. I never thought i would start a war.
Problem solved.
Mods, mark this one resolved.
I got into the second motor. They never did rebuild it for the kid. He got shafted. That stuff inside was as old as the hills. There is no way it had 100 miles on it. Maybe 100,000 miles... not 100. Also, after I took a good look at the oil pick-up tube, and oil pan, it had to be oil starved. Maybe not oil starved at normal driving rpm, but break 4000-5000 rpm and there is no way the oil could have kept up.
It was a bad deal. I hate people.
Now, as for the engine from the other car... Asmodeous' car... I was just cleaning out the filter housing the other night, and there were blobs of rtv packed in the engine side. This is the lack of oil. It made decent pressure, but as for the accuracy of the gauges, who knows. I Am going to hook up a mechanical, "tried and true" oil pressure gauge to it when I get it going, and get a real read-out on pressure. I know the problem and it was extraneous use of rtv. It is not nessesary to dump that much rtv onto gaskets. This is especially true for clean, machined surfaces. Proper torque proceedures, good gaskets, good hardware, and good machined surfaces are imperative to sealing. Rtv is not on that list. RTV is the gasket equivalent of duct-tape. There are certain places that it belongs, and lots of places that it doesn't belong. Also, I could swear I saw traces of copper gasket spray on the headgasket. If this is the case, then I don't know what to say. This is not something I would ever reccomend anyone doing. Bottom line... Lots of stuff was wrong. LOTS of stuff...
-resolved-
