Help, Crazy Camber!!!!!!!!!!!!!!!
JDMFirstGen
109
Jul 29, 2004
Columbus, Ohio
I recently put on a Set of KYB AGX's with intraxs springs, the set was off a friends fwd and my car is awd, I replaced the rear struts with awd ones but not the front, there isn't a difference, is there? Now my car has positive camber in the front, the wheels are making a V, not an A like when you usually lower a car.
Has anyone run into the problem before. Or are the FWD and AWD struts different in the front?
Don't quote me on this one but i always thought fwd and awd springs/struts were completely different. Plus there is no reason you car should ahve positive camber unless you horribly installed them wrong... :confused:
I finally put my car on an allignment rack at work and it wasn't camber, it was toe. My car was so toe in that the tires were being pulled to the inside when I drove. My tires were sticky enough that they would stay pushed in even when i parked creating the illusion of positive camber. (Even another technician at a performance shop though it was camber) I fixed the toe and it is fine now.
