HELP! boost out of control
Onnipotente
105
Oct 16, 2003
When I installed an ebay boost controller the way the provided instructions showed, it worked perfectly, but the blow off valve fluttered and sounded like crap. I re-installed the boost controller exactly the way that was described in the forums, on vfaq, and many other sites. I am boosting like 25 pounds on the t-25 now. I only did this two times adjusting the boost controller completely counter-clockwise and also switched the vacuum lines on the in and out of the mbc just too make sure I didn't switch them up by accident. Is it possible that the vfaq install only applies to ball and spring mbc's because I think the ebay one is a bleeder valve mbc. Please help me. Thanks.
I feel bad I can't help but I didn't want to ignore your question. I did fix the problem, but I honestly can't remember what I did. I don't think its the boost controller though, you must have installed it wrong somehow just as I did. Which boost controller did you buy?
