Heli coil for head bolt
If you would have used ARP head bolts, you would have seen the failure of the coil. I would be buying another block at this point in time. The head gasket is critical to the health of a DSM, any weakness here and you will be calling a tow truck.
If it is not mess up yet, you are fine. Done right, helicoil is tough. If you do have an issue, get the time sert kit or have a machine shop put in one for you. Time sert fits better so it hold great. The kit can be pricy so shop around. Most of the cost of a time sert comes from the jigs to drill the block straight. The time sert itself is dirt cheap.
  • Wanted 6 bolt NT water pipe
    • chrisman287
