For Sale Healthy Eagle Rods/Wiseco 9.0:1 6 bolt Shortblock - $1750
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
As titled.
Have a healthy Eagle Rod/Wiseco 9.0:1 Piston shortblock here.
Includes everything deck down.
Has MHI oil pump
ARP Main studs
Oil pan
Water pump
Water pipe
90 Style OFH
newer timing components
The engine has ~5000 miles on it and 175-182 compression across the board (this was measured cold with bc280 cams).
The engine has only been run on pump gas and with a 16g.
I pulled the pan and inspected the bearings and everything is kosher.
You can simply install your head and run this engine!
$1750 plus actual shipping.
