Headlight conversion (ebay)
I wouldn't get those shitty fake projectors.
Just get a normal set of H4 conversion housings. If you want to run HID's, you can run them in the reflector housing (although not really recommended) as long as you point them way down.
Best possible solution is buying the H4 housings and retrofit a real OEM projector into them and then run HID's. I'm in the middle of doing this right now.
My foglights are 3000k HID and they have been converted to projectors with a good cutoff designed for HID's. My headlights are 5000K HID and are currently in a standard H4 conversion reflector housing, but they are pointed as far down as possible. I have projectors for the headlights, the tricky part is just getting them to fit.
BTW, what color temperature were you planning on running?
