2G Head gasket
zachernest24
May 13, 2013
Poteau, Oklahoma
I have a 85.5 bore. will a felpro composite from advance fit. it didn't say the bore. Will a 85 work on a 85.5 bore?
You don't need a special head gasket for a .5mm overbore. The stock felpro composite will work perfectly fine for your application.
Agreed on the Felpro Composite. The cylinder bore on the Felpro is actually slightly larger than the OE Mitsu composite, although I don't have any measurements/I just put the two together and compared. I'm running one right now on an 85.5 bore. Daily driven. Mods in the profile.
Use L19 headstuds if you can afford them and enjoy.
Yeah I mean I'm working with A friend that uses one and told me it would not blow. I'm at 409 hp at the moment. I know I'm supposed to use a metal but I didn't have the time or money to get the block resurfaced
