Having some suspension issues after hitting curb
jakelandry
985
169
Oct 13, 2009
Minden, Louisiana
Ok before this gets relocated to the curb hitting thread, ive gone through several pages of it. Last night i side swiped a curb. I was being a kid and doing a burnout and my car drifted sideways into a curb going between 5 and 10 mph. So i drove home and ripped the wheel off today. I assumed it was bent so i threw it aside and put a known good wheel in its place. I inspected every component and nothing seemed bent. I did notice my lower control arm bushing seemed to be slightly torn and it diddnt have greese and dirt in the tear so i assume it was a fresh rip. But that was the only thing i noticed. After inspecting everything and putting my wheel on, i took it out for a spin. The only thing i noticed was when i hit the brakes the car makes a sound like the brake rotor is dragging only its more of a rubbing/grinding sound than a squeal or the brake dust gaurd rubbing. I think it is suspension related because it only does it when i put a heavy load on the brakes and only if the car is moving forward. It also doesnt do it if i flat out slam on the brakes.. like it has a certain point where the sound will stop. Does anyone have any ideas what would make this sound?
Check rear brake caliper & slides.
Check ball joint. Bushings. Top mounts under hatch. Shock rebound.
Wheel bearing.
Wheel studs.
Examine rotor. May be damaged or bent.
I checked all of that. I also forgot to mention the majority was taken to the front wheel. The rear wheel diddnt have a scratch on it cause its a stock wheel with a bigger tire whereas the front is 215 35 18. I thought since the curb was only about 5 inches high that the lower control arm would have taken it the hardest. But i really diddnt know how to determine if the lower ball joint was bad.
You could have damaged the front bearing and perhaps even the hub. If it doesn't pull at all, then the knuckle and other steering and suspension components are probably fine.
It doesn't seem to pull any worse than before LOL. I checked the bearing and there's no slack in it. I diddnt pull the rotor off so I suppose there could be damage behind it. I have a es master bushings kit and I haven't done the front of the car yet so I suppose this is a good time to do them... I just don't want to waste my time pressing in bushings if a component could potentially be bad such as a ball joint.
This happened to me last year, not while doing a burnout but rather while turning into a road and not noticing it was all covered with black ice.
I had to replace
Wheel bearing and hub assembly
Outer tie Rod
Lower control arm
Didn't turn out too bad, my wheel has a litte scuff but it didn't dent it, I was only going maybe 5mph.
Hope this helps.
Omar Naranjo Via Sidekick 4g
Well i took literally every suspension part off today and inspected it all. No damage at all. No slack in wheel hub, no ball joint slack, no bends scrapes or rubbing anywhere to be found. It also does it all the time. Not only when breaking. Its a hum that is equally repetitive every time. I dont see how it could be a brake component being as the curb was only about 5 inches high.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
