Having a issue with boosting
tonetone
57
Sep 23, 2008
madison heights, Michigan
I have a 2g awd, 6 bolt with a 2g head (stage 4 head from sbr), agrp 50 trim, dnp manifold, dump o2 housing, apexi n1 exhaust. Miles on everything rangers from 400miles- 10,000 miles...So everything is fairly new. I've checked the gaskets, couplers, boost leak and everything is fine.
Heres the question when i use the EBC and put it on max i only get about 12 psi, when i hook it directly up tot he actuator and skip the EBC my car can only boost up to 4-5 psi.... any help would be appreciated.
yea, source is comming from the compressor housing, got a line that comes from the Intake manifold, then T's off to the bov and goes to either the EBC or directly to the actuator, right now its going directly to the actuator for testing purposes. Its a 1g bov recirculated. I have a fmic.
