Hard starting on cold engine
skipdownstairs
Aug 15, 2006
Manchester, Iowa
I have 255 walboro pump, aromotive fpr, 850cc fic injectors and a stock rail I see alot of these threads that are not going anywhere!! I have noticed on my gauge after I turn the key off the fuel pressure goes down to 0 in less than 2 sec. is my fuel pump bleading off the pressure? and how long should it take for the pressure to drop to 0? The engine starts fine after it is warmed up. I was wondering why it starts ok warm and not cold could it be the isc or a coolant sensor Please help me as much as you can this is very annoying
Thanks, Andy
1995 eclipse gst
It should take hours, not seconds. If the pressure is dropping off immediately, most likely it's either fuel pump/spacer/o-ring related, or a defective AFPR, more likely the first case. Re-check your pump install.
Judging by your injector size, you should have tuning/logging capacity, what is the coolant temperature reading before you start the car?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
