Halo light not working?
chris97pittman
242
May 10, 2004
Bellingham, Washington
Okay I just put my new halo's in and I got everything hooked up and it was a pain in the ass I had to cut the connectors off my stock light and the halo light itself doesn't light up, am I supposed to wire those into the parking lots or does it matter and is seomthing f'd up?
I'm almost positive the halos are the parking lights, try it.
And not to be a smartass, but did you read the directions it came with? ;)
when i got mine, there were two long wires, one black and one red, i ran them all the way to the sidemarker lights and connected them with a T connector and the have worked good ever since, umm if that isnt specific enough, then let me know... ill help
i got my Halos without any instructions, One of mine burnt out in about 2 weeks. I know how to wire it's just the LEDS they use in most of them suck, your better off to rewire a new halo in there. I just think i may just buy OEM lights next time and not waste my time.
Thanks skate enjoi, that's exactly what my lights had so I run both the wires to my parking lights and the halo's should work? then they come on with your pakring lights right?
or you can do what i did
run them to a switch in the dash or where ever
just like neons etc.
so you can control them
they might not burn out as quick if not always on with lights
i wired the halos into the same spot i had my indiglo gauges wired into. i used the cigarette lighter bulb +side(just cut off the bulb, i hate smokers anyways) since it comes on when you turn on the parking lights or the headlights, and just ground the black wires to the chassis.
that way you can just turn on your parking lights and the halos will come on.
