gt35r ball bearing turbo
silkcity100
99
Feb 23, 2003
paterson, New Jersey
i was wondering where is the best place to get the oil for a gt35r, what setups for oil feed are people using for ball bearing turbos and where can i get the fittings ,if i get it of the head,i have about 3 feet of ss lines left over from my afpr setup,where can i get the fitting for the head where it hooks up to a 6an line and also the other end that hooks up to the turbo with a 6an fitting,i also have a earls fuel filter ,can that be used as a oil filter
tnxx
You need to use a 4an line and a restrictor (.8mm) to feed a garrett BB CHRA . Too much oil pressure is not good for BB CHRA's. Call slowboy or Forced Performance and tell them
what you have and they will lead you in the right direction.
