GT DSM manifold
On the number 1 runner(closest to timing belt)
When somthing is tapped that means a hole has already been drilled and threads have been tapped. All you have to do is remove a plug and screw your egt in the hole.
I guess it would be difficult if you try removing it with your fingers. I used a allen wrench to remove the plug, it was really easy.
