GST Exhaust and GS Exhaust - 2G
amskater
121
Oct 4, 2007
LA, California
is there a difference between the 2g GST Exhaust and the 2g GS Exhaust? If so what is difference?
are the mufflers the same? the reason I am asking is im going to need a new muffler soon and some people have told me to just get a GST exhaust put on my GS instead of after market muffler. Would the GST Exhaust add more performance and a deeper sounding exhaust?
would I need the stock GST catback exhaust to use the GST Muffler?
does anyone know if the 96 GSs are 2 inch piping or 2 1/4th piping?
All 2gnt's are 2 1/4. I have never worked on one that wasn't.
is the cat back exhaust the same on the gst and gs on the 2gs?
Yes. I think the only difference is a resonator or something but that doesn't matter.
would adding the GST Resonator make much of a difference?
anyone know where I can find 2g OEM GST Muffler?
Classifieds.
I tried to post an ad in the want ads but it wouldnt let me
It's because you're still a newbie.
Do you know how many post I need to make so im no longer a newbie
[Please read the rules you promised us you did when you joined this site.]
Like has been mentioned, I would think the GST would having slightly larger pipe diameter from stock but they both do take the same route. As for the muffler internals being different, have you looked at yours internally? The stock GST is a single in to dual out. The muffler itself is straight through (perferated core, like most aftermarket mufflers), & each passage in the muffler looks to be about 1.5-2" in diameter, from my memory.
it will be deeper and may give you a better performance gain. Stock GST exhaust is 2 1/4 inch and stock GS is 2 inch. So the 1/4 inch may add a little difference but not much.
Muffler is a direct swap. My stock 2gnt exhaust was 2 1/4 inch, not 2 inch.
