2G stock exhaust size GST
what is stock exhaust size on a 2g GST?is it 2.5?
The stock exhaust size is 2.25 inches.
A quick search would have easily found this information.
I did. But it seemed like all I was getting were threads about n/a. But thank you. I ask cause I had to order a megan downpipe and was told by the rep at extremepsi that it would fit my stock exhaust. But the downpipe has a 2.5 inlet and 2.5 outlet.
I assume you are replacing the entire exhaust, correct? You do realize that most aftermarket downpipes are designed to be used without cats, and if a catalytic converter is required for emissions in your county you will most likely have to cut and weld a high flow in.
Im in nh so not a concern for me. But yes, i will eventually do full. Thank you.
