gs-gst part 4
projecteclipse2
564
Mar 18, 2009
330, Ohio
I ordered my pistons and I got a turbo header and two turbos for like 100 bucks a 16g and a tdo5 the 16g is an ebay turbo but will last till the td05 is rebuilt but the turbo is brand new good but the tdo5 needs to be rebuilt.
Here are some pics.
I will have some pics of my torn down motor tonight or tomorow
turbo pics:
Neither of those are ebay turbos. Not knock offs that is, they may have been bought on ebay. The 2nd pic is of a stock t25 off of a 2g I believe (def not a 16g). The 1st one looks like a 14b.
Edit: 1st turbo is some type of 16g. Part # will help you determine which one.
TD05H is just the compressor housing, both the 14b and the 16g are TD05H turbos.
^^^^ True story.
That is definately not a 14b though, it looks like a small 16g, or possibly a Big16g. The numbers on the compressor housing can help you identify it.
for both turbos.. Not each right?? You said the housings are loose on the 16g?? Thats weird if you have the c clip installed on the cold and the band clamp on the hot side..
