GRRR... weird pop but not all the time.
motrmaniac
119
May 19, 2008
Islip Terrace, New York
ok. soo normaly at WOT. from about 4500 and up full booost. i get a pop like its igniton or fuel cut and then it recovers and pulls hard then sometimes it will do it again. it doesnt do it all the time. i did boost leak test and no leaks. i changed the plugs and put accel 8mm wires on and nothing. i dont know i was thinking maybe MAF or MAP sensor.. i got a check engine light code once and it was for the wastegate selonod. meanwhile its pluged in and just chillin on the side becasue im not useing it. any input?
im not suree i wanna say no. but i have no idea.. im outside tryin to diag the problem along with the 3 other problems i have with it. 1 beign the wipersnot working 2 being the rad fans dont come on automatically anymore and 3 the evap codes. all this happen after i installed the wet kitt. and i cant find anything idssconected or loose.
  • Wanted 6 bolt NT water pipe
    • chrisman287
