Clinical
- 1,398
- 11
- Nov 15, 2009
Cedar Falls,
Iowa
So I'm having a noise come up whenever I get into it.
I've been having some issues with my clutch and transmission lately, to give a bit of backstory - just recently started driving it again.
When I get on it in second, it's usually fine.
However, my 1-2 shift fork is broken and is near impossible for me to shift 1-2 at WOT.
It seems like if I go 1-2(i can if I wait a bit between shifts) or just try to go 1-2 and as soon as I get into second and the turbo starts spooling, I get a grinding noise from the front of the car - doesnt sound like its coming from the tranny area.
It only seems to do it if I recently did a pull in 1st gear at all. Although I can start in 2nd a few times after getting on it in 1st and it'll make the grind. The grind just kind of comes with the spool up, it sounds almost driveshaft related or something. I've never noticed the noise in 3rd or 4th though at all.
This is really confusing me, any ideas? Car isnt any slower when noise is happening either, pulls just as hard.
I wouldn't even drive it. Other than that did you try checking for excessive end play in your turbo? If the sound seems to correlate with turbo spool, that would be my first check.
