Greetings - My car
Jafro
309
41
Jul 15, 2003
Richmond, Virginia
I just finally logged back in to DSMtuners for the first time in ages. Normally I run with the DSMCA crowd, and some of you may know me already. I've been a member here for years, but haven't spent much time here. I just thought I'd introduce myself formally since I never did, and to offer some kind of info or support to the group if I can.
I've never had as much fun with any other car in my life than my GSX, and I've had some fun cars. I've managed to run a 12.67 @ 107mph with a big 16g on pump gas and tuned only by analog gauges and butt cheeks. Here's are some photos of my car, a link to my web page where I documented my most recent build, and my mod list so far...
http://homepage.mac.com/Jafro
Block:
JE 9:1 .020 overbore Forged Pistons
Eagle 7-bolt H-beam rods
Clevite coated main and rod bearings
Balance Shaft Eliminator
New oil pump and front case
Evo External Oil Filter Mount
NASCAR Setrab External oil cooler (Rumored to be Jeff Gordon's)
Eagle Rod Bolts
ARP Main Studs
ARP Head Studs
New OEM water pump
OEM head gasket
Flex-A-Lite slim line fans
* Crankshaft micro-polished and rotating assembly balanced
* Block, mounts and brackets powder coated with high-gloss black
* EVO oil filter fitted with -8AN adapters
* SS -8AN oil cooler lines
* opened up the oil passages and removed casting slag
Head:
* Rebuilt by Ballos Machine
* Ported and polished
* Polished exterior
HKS 264 Intake Cam
HKS 272 Exhaust Cam
Intake:
Dejon Tool 3" MAF eliminator intake
12" K&N air filter
3.5" LS-1 MAF (blow-through setup)
2g Intake Manifold - port matched
EGR Block-off plate
ADFX FMIC (24 x 10 x 3.25")
ADFX short-route IC pipe kit - hacked extensively
HKS SSQV blow-off valve
RRE Manual Boost Controller
Fuel:
RC 550 injectors
AEM fuel rail
Aeromotive Fuel Pressure Regulator (with B&M gauge)
SteveTek SS braided fuel sender and return lines with -6AN fittings
JE Edelbrock inline competition -6AN fuel filter
Walbro 255lph fuel pump
Turbo/Exhaust:
7-cm ported and polished big 16g, unclipped with 34-mm wastegate flapper
SS turbo oil feed line
Ported 2g Exhaust manifold w/EGT tapped in runner #2
4-layer SS exhaust manifold gasket
7-cm SS turbo gasket
Ported 2g o2 housing
Apexi 3" N1 Downpipe
Apexi 3" N1 Exhaust
Electronics/Gauges:
Fuel pump rewire
2g/3Si Ramchargers LS-1 MAFT translator v 2.01
Greddy 60-mm Electronic Boost Gauge with Peak/Hold
Greddy 60-mm Electronic EGT Gauge with Peak/Hold
Jumptronix A/F meter
Suspension:
Totally stock.
Transmission: *
TRE Full rebuild on 10/2001 and on 11/2003
4-spider center differential
Double-Synchro 2nd gear
Upgraded 1-5 synchro materials
Heavy Duty 3/4 gear shaft
Top Speed 5th gear set (10% taller)
EVO Stainless Steel 1/2 Shift Fork with Bronze wear pads
EVO Stainless Steel 3/4 Shift Fork with Bronze wear pads
Heavy-Duty Neodymium trash magnet
Magnetic drain plug
* Always used BG Synchroshift II in transmission
Clutch:
ACT2600 2600-lb. pressure plate with street disc
Stainless Steel braided clutch lines
Removed Clutch Accumulator Reservoir
New OEM throw-out bearing and retainer
Brakes:
OEM 2-pot front calipers
SS brake lines
Wheels and tires:
1995 Eclipse GS 5-star 16x6" wheels
Nitto 555R Extreme Drag 225/50R16 radials
All That and just a 12 second timeslip...
Maybe you should Dyno tune that beeotch, I think you could get much better times out of it.
Nice looking ride, very clean, no rice :) :thumb: I like it
That's exactly what I was saying when I ran that. ;)
It's a full-interiored 3350lb car with me and everything else OEM still in it.... ABS, SRS, AC, cruise, hood, Stereo, spare, jack, etc... I know I need dyno tuning and I have no means of datalogging it. Tuning the MAFT without datalogging on a 2g is a near impossibility. I think I could improve it substantially if I had the $ for DSMlink, and a less conservative tune. It's running really rich.
I'm not into the body kit/aftermarket wing thing. I went with 2g GS wheels to try to look less fast, but the drag radials, vented BOV, IC, and the exhaust blew that one. :rolleyes: Oh well. I like 'em a lot better than the swirlies.
tom1995tsi said:
Awsome Car I wish i could make all my stuff crome like that :thumb:
It's all polished. Chrome is a heckuva lot easier to keep shiny. I won't drive this thing in the rain. :| You might not like that part of it.
