Greddy type S install question with external Wastgate?>?
CrzyTalonAWD
Mar 23, 2004
Turner, Maine
I am having some problems installing my Greddy Type S with my Tail External wastgate. It doesnt blow off like my friends Talon does and he has the stock turbo with his stock wastegate. I am woundering how to set this up. I know the bigger nipple at the top of the wastegate goes to the original line then the other nipple which is under that one is supposed to go to you wastegate. However with an external set up how do i run that hose, the top of my wastegate has a whole that has nothing in it. THen the other one on the side of the wastegate has a screw in it with a hose to control my boost. Now i am woundering if that top whole where the screw sets into, is that the hose i connect to the other nipple or what? Or do i go from my stock wastegate and run that hose up to my BOV i dont see any real diffrence yet, all i hear is a faint ####shhh then a squeak in the middle of the whoooosh. i am a little lost and i hope someone can point me in the right direction. I installed the BOV exactly how WWW.VFAQ.COM stated however there set up is on the stock wastegate.
Thank you,
Scott
All the BOV needs is a boost source from the intake manifold. Have you tried adjusting the bov?
the top nipple on a tial wastegate vents does not have any line on it.
The one in the middle of the wastegate goes to your vac source.
do you have a boost controller, if you do, the middle nipple will go to the boost controller, the other nipple on the boost controller will go to a vaccum line with a "T" fitting that will go to the intake and the bov.
So the nipple on the side of the wastegate goes to one of the nipples on the MBC and the other nipple on the MBC goes to a T-fitting between the type-s and the intake manifold, right?
On the Type-s I should use the top nipple and if I can take a boost reading off the turbo that should go the bottom one, correct?
Hopefully this is correct,
Krummel21
