4ged4G63
- 426
- 11
- Sep 6, 2002
Gotham,
Illinois
is your car red?
Originally posted by candela
I definetly think the spal pushes way more air and possibly cools better. I dont really know cause I got it all at the same time, and its never overheated once...I definetly recommend a fluidyne, they look good and perform well...![]()
Originally posted by 4ged4G63
is your car red?
Originally posted by JoeyGST
Larryd: Did you install the turbo with a kit that came with new water
pipes, or did you bent your stock pipes to work?
I bent my stock pipes, and they are kind of beat up, I think they might
not flow too well. Do you know if ALL of the coolant in the system has
to flow through those two pipes? Or is that a seperate path?
good information dude, thanks. I went to nexfan and looked around. I found this fan that flows about 65 cfm. Two of these floowin 130 cfm would probably be effective. And they are cheap too, about 20 bucks for two. Oh, and its ball bearing tooOriginally posted by Beemer
Actually, being an avid autocrosser, I encountered this overheat problem constantly due to 8 grand in first or second gear going thru corners. What I did? You will laugh when i tell ya....
I went to a motorcycle rebuilder and bought 3 electric fans from a liquid cooled honda 500 sideways v-twin street bike. They were a perfect fit for my fmic, and forced enough air up thru it to give me the extra airflow i needed over the radiator. you could also order some big hi velocity computer case fans...they are 12 volt as well. Mount them with 6x9 speaker bolts and a piece of plastic on the bolt and nut side to keep them secure, or zip ties (ghetto, but it worked for me)
I agree with canning the ductwork and getting your fan shrouds back on, especially the shrouds. They create a vacuum so the fans pull cold air from the front of the bumper instead of sucking hot air from around the engine and then blowing that back. For the guy with the SPALS, I would run a toggle switch to a ford starter relay and then run straight from the battery to the relay and out to the fans if I was you. You can hook the relay wire to the fuse box on an accessory line that is open, and it draws very little power compared to trying to run the power for 2 fans thru your wiring harness..
If i was still running my FMIC I would email you a pic, but i went back to my alamo sidemount with an alcohol/water spray bar because one of my sponsors thought all the fans in front (or behind, i tried it both ways) was stupid looking and he thought the fans blocked airflow at 100 plus on the straightaways. BTW, those computer fans can be had with ball bearings and they can move some serious air... try bestbyte.net or nexfan.com for info on smaller fans up to around 120mm or so
... I put a fan that flows 600+ CFM on Pete's car when he was having cooling problems -- and they basically went away after that.
not you mr. BlackGSXsittingonjackstandsOriginally posted by Black95GSX
Who are you directing this comment to?
I never said that dufas. I had only scrolled half way down the page when I found those. Where can one get some fans that flow " 600+ cfm" that weigh next to nothing?Originally posted by Black95GSX
John, You know for a FACT that those 12v computer fans will flow well over 700cfm![]()
oh master cooling expect, is there a solution that one could purchase to flush and clean the deposits out of the radiator?Originally posted by Black95GSX
.....your radiator WILL get deposits in it (unless you use distilled water, and never anything else) from the minerals and other "crap" in the water, you get build up. Build up will make life even harder for the radiator to work... since the build up acts like an insulator keeping the heat in the radiator even further.
damni t dude, I was being sarcastic and serious at the same time. You need to start recognizing this.Originally posted by Black95GSX
Okay mike... thanks again for being sarcastic as hell
Don't trust those "flushes in a bottle" -- I would NEVER do something like that to my car.
