GReddy e-Manage
marcman804
484
11
Mar 5, 2005
Cumberland, Virginia
I just purchased a GReddy e-Manage off of eBay and it came off a Supra. I have a 97 GST and I was wondering what is all I would need to install it on my car. Do I need an EPROM ECU?
It came with Support Tool software as well. Will I need a harness for it? Is there a FAQ on here that could help me out? Any helpful information would be a lot of help. thanks a lot. :dsm:
You do not need an eprom ecu, you pretty much just splice the harness wires from the emanage into your ecu. You will need the emanage injector harness, and ignition harness. I have have heard of people getting away with just using the injector harness, but wouldn't recommend it. My buddy got both of his harnesses off of ebay too.
marcman804 said:
Does that apply to my car. because it says 1g not 2g. :dsm:
First of all you need to get the installation and operation manuals for the BLUE emanage then read them carefully. Also you need to get the leatest UPDATED version from http://www.mohdparts.com/emanage/index.html.
Regarding the wiring, you need at less the injector harness and it is the same as hooking up AFC with 5 more wires for the injectors. In my opinion, you should also get ignition harness and the MAP sensor to use all functions of it and make it worth.
Good Luck :dsm:
4wd-Eclipse said:
Regarding the wiring, you need at less the injector harness and it is the same as hooking up AFC with 5 more wires for the injectors. In my opinion, you should also get ignition harness and the MAP sensor to use all functions of it and make it worth. :dsm:
It's a piggy back, but it allowed me to run 12.0's on a s16g and stock IC and piping with water injection.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
