Got it running, but more problems (water pump)
Shadowofoblivio
87
Feb 7, 2005
Farmersville, California
well i got the car back together and it starts just perfect and everything but it acts weird under boost and after a little bit it will forget how to idle and just die if i dont give it gas. also i went to fill it up with water the next day and water was leaking from the little hole on the waterpump.
how long does it usually take to replace the waterpump and what do you think is making it die at idle?
nevermind the whole water pump thing because i allredy have it replaced. the only thing wrong witht the car now is that after it warms up it wont idle it just dies. the iac is making allot of noise like the comp is moving it but its a little loud so does anyone think that this could be the problem?
    • dsmmario
    • Canadian_CD9A
    • my98gsx
  • For sale 4G63 Six bolt cy head. Ported. SS O-rings. Ferrara valves.
    Six bolt cy head. Hand ported and flowed by Baker Cylinder heads. He started at Air Flow...
