Got a Problem Need Help!!!
Speedee89
Jan 14, 2011
Valdosta, Georgia
OK I'm Got a problem with my engine, while driving down the road i my decides to as i call it studdard as if a coil pack is breaking down, pulls an egr code. but with my aftermarket header i have eliminated the egr just lacking block offs.:confused:
Hmm, you eliminated your EGR system but didn't put any block offs in? So you have a big hole on the side of the head and you have a big hole in the back of your intake manifold? I guess that would explain your problem, but I'm thinking you may mean something else.
Also, if you do eliminate your EGR system, you WILL throw a code for EGR malfunctioning........
MB
  • Wanted 6 bolt NT water pipe
    • chrisman287
