going to the tracks tomorrow
h3o
290
6
Mar 11, 2005
everett, Washington
well going to the tracks tomorrow i ran a 14.7 stock the last time i was out
this time i added
255lph hp walbro
2100 act clutch
safc2
eprom stage 3 chip
open downpipe
225/50/15 bfg drag radials 17psi(adjusting)
1" coil spring spacers
lightened to 2700lbs (thank you cut off wheel)
datalogger (hopefully i can get the damn tunerstien to work properly)
110 unleaded octane
tuned to .89 o2 voltage with 0 knock and 3 degree timing advance at 20 psi dropping to 17-18
im hoping i can hit a low 13, so wish me luck ill get back here on monday this is a 2 day event starting tomorrow afternoon
sounds like great fun! i missed our local track day yesterday... o well i was installing hardpipes :) goodluck man -Ryan
good luck man. i have to get slicks before i can run again. i spin just about half way down the track. it sucked. i think my best time was a 14.4 :mad: :mad: :mad:
okay got some bad news, my flywheel cracked on the way to the track ( i guess its that time) got another one from a donor but no machine shop. we tried to install it this morning, it goes in but clutch wont disengage o well looks like i gotta wait another month.
damn the only that sucks is i have 5 gallons of 110 in the tank and no track to use it on $35 up in smoke (literally)
this time i added
255lph hp walbro
2100 act clutch
safc2
eprom stage 3 chip
open downpipe
110 unleaded octane
A few guys have run 13s with alot less mods than you, so with the drag radials you should definitely be able to pull it out.
Good luck :thumb: :dsm:
