Going to the green what times are you guys runnig what to expect in tuning !
v8killer
371
5
Oct 4, 2002
harlan, Kentucky
What should i expect or look for in tuning this thing ! i have heard they are problems with the internal wastegate should i just port the hole. i have a 3inch downpipe full 3" exhaust and tubular o2 housing !
I recommend Link and AT LEAST a set of 750cc injectors. You are FWD, so to run good times you will need a set of super sticky tires and a good amount of suspension modifications.
As mentioned above by josh.
Get yourself a dsmlink, a 255, afpr, and a set of 850cc or 1000 to give you ample room for improvement should you need it later down the road, better safe than sorry.
As for the internal wastegates i have never heard a complain of fp's wastegates, if it really bothers you, get a tial 38mm.
well i have tunerpro and a rewired 255fp and adj fpr also have 850cc injectors already ! i hope the wastegate works good..... anyone know how much boost people are getting away with on pump 93 !
