gm maf placement
talon96tsi
182
Feb 16, 2003
Westminster, Maryland
:confused: i know of 2 different places to mount the gm maf, the stock position and the uicp. is either of them more efficient then the other? thanks
mounting it as close to the throttle body as you can gives you the atvantage of avioding boost leaks as far as metering goes. If your leaking boost before the MAF you won't run an inacurate a/f ratio because of it. Also if you blow a I/C pipe off, you can still drive home.
