Gm Maf Or New Bov??
KeithL322
42
Oct 6, 2005
Clarksville, Indiana
Ok guys, heres my question....I'm running a xs RFL blow off valve(vented to atmosphere) but i wanna fix it, just cuase i know its bad.... and my car will die if i drop clutch from over 2K RPM's(im assuming venting is the problem)....ANYWAYS, should i just go with a GM MAF and MAFT, or buy a new BOV that can recirculate?? how much would it cost to do each one? which one will be better if im wanting to do a little work to my car?? (no more than 400 HP)
I dont kow if this will make any difference but I already have an S-afc b...but i need to hook it up the right way
I was thinking just go with the GM MAF and MAFT jsut cause I already have a blow off valve for it, but what all will i need to buy(I mean EVERYTHING) to complete the change,if I decide to do that? Help would be GREATLY appreciated THANK YOU!!!
you wouldnt have to buy a new turbo to recirculate, just get a BOV that recirculates... but since your planning on upgrading your car buy the gm maf and MAFT, set a base tune with it (injectors, idle), then use the afc to tune the rest (low throttle, and WOT)
yeah i didnt mean new turbo LOL, used wrong word i dont know why, already changed it tho... do you have any clue how much it will cost ??
dont forget you will have to modify your UICP for the translator. So either
A) new pipe from dejon or similar or
B) 2 silicon reducers from UICP to MAF and back to UICP. that can raise the overall cost a bit.
I say translator. rather than buying a new BOV again.
depending on how far you wanna mod. your car your gonna wanna get the maft setup sooner or later. :thumb: i say DO IT Do IT
