glow gauge inverter
97EagleTalon2nr
126
Aug 4, 2004
Maynardville, Tennessee
I have some white reverse glow gauges i got off ebay, i had them in my car for about a month and the inverter went out, so the other day i ordered a new eurolite which ive heard is a pretty reliable brand, i plugged up all the guages to the ivnerter and butt connected my positive to the existing positive from the old inverter and the negative to the existing negative, the negative is on a 10mm bolt u can see when u take the cluster out, and the positive is on one of wires on the big connector on the far right that plugs into the gauge cluster, i got this all together and i was making sure they worked and i had them on about 2minutes, so then i turn the car off and continue to put the cluster in and when its all back together they dont work:confused: i have a good ground and im getting power i also double checked all of the conenctions to the inverter, and i know it didnt pop the fuse i have the guages powered off of, any help is appreciated, thanks
