Ginding 1st and 2nd
Synapses
425
May 9, 2005
Dawson Creek,
Ok so when I'm shifting, with the clutch fully pressed to the floor it ginds a bit when shifting into 1st and 2nd. This is makeing no sence to me. What is causeing this and what can I do to fix it :confused:
Sounds to me like a few possibilties one is that the clutch needs to be bled. Two is that your synchros are going bad. Other than that check your shift linkage, your slave cylinder, or clutch master cylinder. If it is only 1st and second I would say synchros from experience. Dont mean to upset you I know trannys arent cheap
