Getting ready for surgery - opinions wanted
DailyDriven
Supporting Member
74
7
Apr 29, 2011
St,Aug, Florida
CAR AS IT SITS TODAY
1997 GS-T 150,000
New head, timing belt and water pump changed.
PR fmic
Fake rs bov - Leaking
t-25 hacked for fmic :ohdamn:
boost gauge and mbc
Catback 3" exhaust
PARTS WIATING FOR INSTALL
Evo Maf & pigtail
Evo 560 injectors
fp evo3 16g
evo3 o2 housing
ebay 16g install kit (my turbo has all oem lines on it)
arp head studs
190 fuel pump
Synapse bov
Wideband will not be purchased tell after the 4th of July, how much boost do you guys think I can safely run with all parts installed? I was assuming based on the evo and the fact i will need a little more boost to compensate for the maf/timing, I would be safe to 18psi.
Let me known what you guys think. :thumb:
Alright, i decided to hold off on installing the downpipe and arp headstuds. Im going to wait tell i can afford to purchase the wideband. The evo3 16g, evo maf and 550 injectors at 15psi feels strong. My reason for leaving the stock downpipe was to avoid boost creap, holds solid at 15psi. I know my knock off greddy bov is leaking but im missing two o rings for my synaps so hopefully i will be able to get them tomorrow. Install was pretty smooth tell one of the manifold bolts gulled(i used anti seize but i put them in with an impact). I recommend not purchasing the ebay install kit, was a lot more trouble then it was worth. Ill post some pics once the car is cleaned and the synapse bov is installed.
