GC coilover questions
90tsiPA
118
Aug 5, 2007
Hanover, Pennsylvania
I am picking up some lightly used ground control coilovers on Agx shocks within the next day or two and I have some questions. I checked the part numbers and for some reason the spring rates are alot lower than most people run 280lb front and 200lb rear.
Is this spring rate common?
Am I going to be at a disadvantage using those lighter spring rates?
What will I have to change to put these springs on koni yellows?
Do you or anyone have any insight on this particular spring rate? The car they came off is a 700whp galant vr4 from my town and the guy didn't really drive the car and didn't have any complaints about the setup. I'm coming from bone stock/blown suspension and if these springs are going to let my car squat really bad still and not handle well then I might look else where.
