Gauge Bezel / Pod Question
BaddAssGst
1,054
21
Dec 27, 2004
Toledo, Ohio
Does anyone know if they offer a 60mm gauge pods? Everything I see is for 52mm gauges but I ended up ordering an AutoMeter 60mm gauge because my old Greddy gauge was the same side although my AutoMeter is a little bigger then the Greddy.
I'm looking for the vent pod where I can mount the gauge and an AFC II. I can't seem to find anything. I was thinking of getting a 52mm bezel and filing it down to fit but that seems like there won't be enough area to hold the gauge in place.
Any ideas? :confused:
check out MachV Motorsports they have a lot of different kinds. The 2g gauge bezel gives you the option of 52mm or 60mm. Not sure w the 1gs. You can always call them or take a dremel and shave it wider a little.
I dremeled mine out. It was a PITA if you ask me, and wouldnt do it again, but it looks alright. It currently has 2 greddy 60mm P/W/H gauges in it. I have a picture somewhere of it if you want me to post it.
Yeah that's what I'm afraid of. The pod won't be strong enough to hold it in place, if it would even fit since I also have an AFC tied in with it.
I looked on LoTek, Autometer, ProParts, and Megans websites and couldnt find a 60mm 1G pillar. It appears you are going to have to buy a 52mm and carefully dremel it out for the bigger gauges. It shouldnt be that hard. If you take your time it will probably look just fine too.
Yeah I have a pod for a 52mm but you can't dremel out enough material to make the gauge fit. It's a very tight squeeze.
Guess I'll send it back for a 52.
Thanks for the help.
