gasket beween b16g and j pipe?
civickiller
119
Nov 6, 2004
Salem, Oregon
is there supposed to be a gasket between 16g j pipe and the turbo? :confused: if yes, where can i buy it? I need to know this before i install my b16g.
thanks
Paul
I just used a bead of blue RTV, I let it dry a bit before putting the j-pipe on though so it didnt squeez all out. I boost leak tested my car to 20psi with no leaks there.
or you can buy some gasket maker from any auto stores and make the gasket yourself :sneaky:
99gst_racer said:
Any Mitsu dealership will have them too. It's the same gasket between the j-pipe and the 14b on any 1G.... I had a cracked gasket on my old 14b and it leaked. Then I tried RTV with no luck. Just spend the .75 at the dealership and you'll have no problems. :thumb:
thanks guys, :) i will go and get one from dealer
p.s. can i use j pipe off 14b? or do i need a bigger one for 16g? :talon:
a 14b and 16g use the same compressor housing so yes you can use the same one.
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
