gas pedal feel
Got Boooost
113
Jan 9, 2008
Airdrie, AB, Canada
Hi gus,
I've got a 75mm TB from BBK, and Ive noticed that the gas pedal is really soft now. does anyone know if i can buy a differnet throttle spring? or is there a different method to fixing this problem? or am I stuck with?
thanks for the help
Vern
Soft like spongy because it won't return like it is supposed to? Try lubing up the cable?
You still have Cruise?
edit, check your cruise box and make sure everything's tight and has no play there, I hate that setup.
i'll try lubing up the cable, and cheeck to see if i need to adjust the cruise control box where it meets the throttle cable. I did remove the crusie control, maybe that has something to do with it.
thanks for the help.
Vern
